AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Problem with crosshairs and x, y, and z planes
2 REPLIES 2
2277 Views, 2 Replies
Hi, I am having a weird problem in 2006 LT.  I received a drawing from someone who has a later, non LT versio.  They saved theirs so I could open it in mine. After working in their drawing for a while, I decided to save as and create my own copy.  I worked in the new drawing for a while, and one day I opened it and noticed that my crosshairs are at a weird angle and my UCS icon is not normal.  Since I could not figure out how to fix it, I decided to copy all my work into the old drawing.  When I did, it comes in as a line.  I checked the work in the new drawing, and all the lines are drawn on the xz plane instead of the xy plane.  I know that LT is not supposed to have 3D, but that is what is going on. BTW, the xz problem only seems to be affecting model space.  I managed to get my crosshairs back to vertical/horizontal in model space, but now they are skewed in PS.   I have attached the drawing.  Any ideas how to convert the z axis back to y ? Thanks.
2 REPLIES 2
steven-g
LT has 3D coordinates, somehow your drawing plane has either shifted or it came in that way (the UCS is set to front). Type UCS followed by VIEW and your crosshairs will line up again. The geometry is angled so you could type UCS followed by W to get back to a normal drawing plane.
Just in case Attached is a copy with everything placed back with the World UCS which mucks up your paperspace layouts but it might be easier to use.
in reply to: steven-g
Thank you SO much!  That worked perfectly!
”Boost
