AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Printing to a PDF creator, like CutePDF
6 REPLIES 6
lokimeister
4866 Views, 6 Replies
When I go to print to a pdf creator, I get the entire file location, including what layout, in the save as file name line:
S__AutoCAD_Drawings_Cabinet Drawings 625 and 1375_20104-02 Layout1 (1).pdf
What I would really like is just the file name, 20104-02.pdf, in this case to show on the file name so I don't have to delete a bunch of characters all the time.  I had this on my old PC, can't seem to remember how to do this on the new one.
Thanks for your help.
 I have included a picture.
6 REPLIES 6
hwalker
in reply to: lokimeister
What version of LT are you using? The newer ones can PUBLISH to PDF. And they will only have the file name in the saveas box
Howard Walker
Left Handed and Proud
Yong.Jing
There are serveral methords to create PDF file in AutoCAD LT.
1, Export > PDF,
    The created pdf file name is same as dwg file name.
2, Print > Plot > DWG to PDF.pc3
    The created pdf file name is <dwg file name>-Model/<Layout>.pdf
Methord 1 could match your requirement.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
lokimeister
in reply to: Yong.Jing
Honestly? The ExportPDF command is nice but then I have to change the
folder all the time.
DWG to PDF.pc3: As I said, I would have to change a bunch of files,
PITA. Previous versions didn't have this issue.
I will be out of the office starting Aug. 18 and returning on Sept. 2.
Kevin R. Entwistle
President
Galva-Closure Products Co.
(608) 873-3044
Fax (608) 873-1331
www.ctcabinets.com
"That which you manifest, is before you." Enzo from The Art of Racing
in the Rain
hwalker
As I have already asked. Which version of LT are you using?
1. The newer ones when you choose publish there is a option called PUBLISH TO and the options are
Plotter named in pagesetup
dwf
dwfx
PDF.
2. In the same dialog box there is a PUBLISH OPTIONS.
One of the options is DEFAULT OUTPUT LOCATION (PLOT TO FILE).
You can change that to any directory you want.
Howard Walker
pendean
If you didn't understand the first reply to your post then ask: ignoring good advise is not the way to solve a problem.
lokimeister
in reply to: pendean
The version is LT 2015.
You are correct, and I have been rude and I apologize. I have re-read
the thread and noticed the default output that I can change.
I appreciate your keeping up on the thread.
Okay, that is actually pretty slick. I like how I will be able print
multiple open files at once.
Kevin R. Entwistle
President
(608) 873-3044
Fax (608) 873-1331
www.ctcabinets.com
in the Rain
”Boost
