I have these plines that keep appearing in my drawing that are not on a layer (see attached). I have never experienced this before. There are 10x duplicates stacked upon one another surrounding three separate shapes. My theory is that a hatch is creating them. I deleted them and they came back. How do I manage them and their display properties, or better yet, remove them from the drawing.
I will try to extract the problem area and attach. I pobably won't get to this for a few more hours.
As a follow up, when I run AUDIT, this is the result:
Total errors found 30 fixed 30
Erased 0 objects
AcDbPolyline(C4DF0) Invalid layer eWasErased
etc... for all 30 objects
These are the culprit lines. The AUDIT moves the plines to the $AUDIT-BAD-LAYER. I can delete them from this layer and then purge the audit layer, but I have done this already. I think they will reappear again.
Use RECOVER to open the file, then PURGE everything. SAVE.
Now WBLOCK out the content of the file you want to keep to create a new file. Do not INSERT or IMPORT anything else from the 'bad' file.
90% that cures problems similar to yours.
If they re-appear later, find out if it is after you INSERT or IMPORT something from another file or not.
