AutoCAD LT Forum
PAT fILES
8 REPLIES 8
Message 1 of 9
1035 Views, 8 Replies
PAT fILES
How do you install new hatch patterns in LT2006. Where are the pat files?
Thanks, George
8 REPLIES 8
Message 2 of 9
Simply copy them to a folder that LT searches (Options command>Files
Tab, first category), then use BHATCH command, Custom option, and
there they will be.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 3 of 9
Oh, and each PAT file must contain only one hatch pattern definition,
and the file name must be the hatch pattern name.
Dean Saadallah
Message 4 of 9
JanneZack
this does not work.  I've pasted my custom .pat files (that I've used for years) into every known file folder and they still don't show up.  I don't even have a "CUSTOM" hatch pattern tab on the BHATCH command window.  Any other ideas?
Message 5 of 9
pendean
in reply to: JanneZack
OPTIONS command's FILES tab, top listing for "Support File Search path" are the only folders your session of AutoCAD looks for PAT files. You can either add a folder to this list or use one that is already there. Screenshot #1.
HATCH command's pop-up has a Custom option, see screenshot #2. The Ribbon does not, it list all it can find.
Message 6 of 9
JanneZack
in reply to: pendean
Thank you, I finally figured it out myself.
For FUTURE readers, the trick is to do the following:
Put your PAT files into any folder on your computer (I made a new folder within my documents)
Open Autocad,
CLICK:  Tools
CLICK:  Options
CLICK:  the FILES tab
CLICK:  on the "-" sign beside the first category called "Support File Search Path" to show all the files inside that folder.
CLICK:  (on the right side) "ADD"
CLICK:  BROWSE (go find the folder you made that has all your PAT files in it).
CLICK:  OK
I then found my custom hatch paterns under the locations as shown in the screen shots that were posted above.
HOPE THIS HELPS!  Thanks again for all the help!
Message 7 of 9
JanneZack
BY THE WAY,
I learned this bit of the puzzle by googling it on YouTube! It was about the third video down in the list and didn't have any sound, but if you read the comments that flash up, it was quite easy.  (I'm not a computer guru, but only had to watch the video twice.
Message 8 of 9
Charles_Shade
I guess those screen shots would have worked if they had been animated.
Dean you need to step up the response a bit...
Message 9 of 9
pendean
in reply to: Charles_Shade
LOL... I just need to update my YouTube Vid Library links list instead 🙂
”Boost
