Please see the linked video. I reinstalled Autocad LT 2013 and it did not help.
https://www.dropbox.com/s/exhvgqwhfdjzuwz/IMG_3632.MOV
Casey
There is not a LT fix for this. This is normal on a computer with lower specs. What are the specs for your box? Is it just the baseline (i.e. 2gb ram etc...)? If so then this is to be expected; better performance comes with better hardware.
May I ask why it is imperative for you to see all the objects you're moving? If you pause while in the middle of the move command, you should see things starting to come back.
(if ("mysolution"=answer) then (click "Accept As Solution"))
Mac Forum:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
DRAGP1 Variable
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
