Any word on when LT will have object enablers available to diplay the ACAD Arch & ACAD MEP objects?
The ACAD Civil is the only one posted.
Solved by pendean. Go to Solution.
Those that know cannot say, and those that say do not know 🙂
LT2011's OEs came out late for some reason if that's any help.
OE's for Architecture & MEP objects are built in to the product now. But if you have a file that's not displaying properly, please send it to me (kate.morrical@autodesk.com).
Thanks for that info Kate...Do you know if this is also true for DWG TrueView 2012?
Well Im running ACAD 2012 and ACAD MEP objects from my Electrical Contractor (Done in MEP) are showing as simple AEC Proxy blocks.. "yea".. maybe an enabler wouldnt be a bad idea.. just in case.
Kate,
Here is a file that is displaying fairly ok, but I get a dialog box asking for proxy graphic information. It was created in AutoCAD 2012. I just want the dialog box to stop popping up every time I open the file.
Your help will be greatly appreciated.
A. Lawrence
Set PROXYNOTICE to 0 (off): look all these "proxy" commands and variables up in HELP, they all start with the word PROXY.
Thanks Dean.
I have another question: How do I set up a pen settings file?
Regards.
Anthony
PLOT STYLE TABLES? start with one of the free one provided to ensure it has the "color" output you want, then make a copy of it with STYLESMANAGER, give it a unique name, then edit the linewieghts and test until you are satisfied with the results.
i have my new autocad lt 2012 installed in my computer but when i open my drawings, there are text missing. how will i fix it?
what i mean is, the text is not displayed on the drawing. some is displayed some is not. I used the older version of CAd (2008 LT) but when they change ti to LT2012 Lt, those text dissapear. Please let me know how to fix it. I couldnt find an object enabler for Autocad 2012 LT as well Object enabler for Mep.
Appreciate your help.
- Did you check to see if that layer was frozen/off?
- Do you use ANNOTATIVE Text? if yes, is it a matter of resetting the annotaqtive scale to 1:1 then back to whatever it needs to be?
- Did LT2012 not find the font and create a substitution? When you open a DWG file AutoCAD tells you of such an even. Check your STYLE settings.
- Are you missing an XREF with those notes?
- Are this Mtext or TEXT objects that are missing?
Investigate the cause as noted above, don't just report a symptom: there is no LT2012 Emabler for LT2008, never has been, never will be. That's not what 'enablers' do.
I've dowloaded the latest service pack, and AutoCAD Civil enablers, but I am still unable to view proxy objects, such as doors and stairs, in a file created in AutoCAD Architecture.
Any input would be greatly appreciated.
There does not seem to be an OE for Architecture for LT 2012
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20129401&linkID=9240818
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14896138&linkID=9240818
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
We are end users like you: so far you are not addressing anyone that works for Autodesk here. Sorry Friend, this is peer support. if you want Autodesk support consider buying a subscription that offers it.
Enablers are not automatic for all versions: someone somewhere decides if LT needs it or not and then develops it. If it's not listed on the website it's not available. And since LT2012 is no longer current I'd be very surprised if any is ever developed in the future.
To remove AEC content from a file, the originating AEC program needs to "export to autocad" to destroy the objects back to AutoCAD entities. Sometimes, not always, an equal or higher version of AutoCAD/LT with the correct enablers installed can do the same with -EXPORTTOAUTOCAD command (as long as it can see these objects). SAVEAS is not the fix, never has been.
Hope this clears up what is needed for a fix for your file(s).
