I have been having problems with my program for a few months and have posted questions seveal times for individual issues. Today I kept a log of the problems that cropped up in a 2 hour window of constant use. I have no idea what is happening, I have made no changes to the preferences or downloaded/updated anything to the computer.
I am using Audocad LT 2013 using Windows 7 and FusionWare on a MacPro with OSX Lion. Note, I am using it as a PC not a Mac.
When I write Freeze what happens is that the screen and cursor freezes for up to 1 minute. If I click the mouse a message appears in the title bar (Not Responding) and the Windows 7 Start menus pops up to the left side of the screen and the screen fades out for 15-30 seconds. I have tried another mouse with the same results so that is not causing the problems.
9:48 Activate Stretch command - freeze
9:51 Click to select an object - freeze
9:56 Spontaneous freeze with out clicking anywhere
10:13 Trim, right click to select all objects - no results
10:15 Click to select an object - freeze
11:07 Object highlighting stops working
11:08 Click to pan - freeze
11:11 Object highlighiting now working
11:12 Object highlighing stops working
11:13 Save - freeze
11:21 Click on Layer to expand the window - freeze
11:30 Global trim fails
11:33 Select Offset command - freeze
11:39 Select Mirror command - freeze
11:45 Click to select an object - freeze
11:50 Select Copy command - freeze
Got frustrated and went to lunch.
Obviously this can really slow down my productivity. But it only happens in chunks, I might be able to work steadily for seveal hours with no problems then there will be several hours of constant lockups and failures. It's getting too weird. No one else in my office has had this problem.
Everyone else in the company on Autocad is using a PC. Because of my work I need to be able to utilize programs and share work with co-workers using Macs. So this was a compromise.
The issue is out of my hands. I am a bridge between the Planning department and the Creative department. I usually spend the day bouncing between the Mac and PC sides of my computer and it would be too expenisve to expect to have 2 different computers. And if someone else needs to get onto my computer to use AutoCAD or a Mac program this was viewed as the acceptable alternative.
And my manager is not an AutoCad user and has little understanding of technology except how to use email and play games. Even the IT department are more Mac focused than PC. The FusionWare setup was extablished by a previous IT tech so the new guy isn't really sure about how it all works either! Those of us who use PCs are in the minority here.
So, I can't change the set up. I am asking for some insight into what is causing the problem. Until I have something concrete to take to my manager and can say because of THIS, I need THIS, I can't do anything to change it.
Because of the numerous problems that you have posted I should think you already have what you need to tell Management to get what you need.
Worst case for the IT guy: A new IT guy.
Worst case for the Management: Let them keep paying you for taking too much time to complete what is needed because the tools are inferior.
Dang - I think I just understood Dilbert!
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi Katie,
Forgive my ignorance, but what is actually FusionWare? Is this an application name? Do you mean VMware Fusion application?
If so, which version do you use?
What Network settings do you have for virtual machine, where you run AutoCAD LT?
Maxim
I am not an IT expert but it was explained to me that FusionWare is a program that lets you partitian (?) the harddrive and operate the computer as 2 separate entities. I can either use it as a Mac with OSX, or as a PC with Windows 7. There is no commuication or shared software between the 2 halves, although items on the desktop are visible and accessible to both systems.
I have no idea what version the FusionWare is and can't figure out how to check it, it doesn't show up in the Programs list and right-clicking on the header doesn't show Propeties.
And I don't know what the Network settings are.
Don't know about that, the IT dept are always working on the server. Whay would changes to the server effect a program like that? And only that one, none of the others have problems.
I meant none of my other programs seem to have problems. Admittedly AutoCad is the primary program I use with FusionWare, the others are Safari and Acrobat. Everything else is on the Mac side.
One other person has the same setup as me and doesn't seem to be having the same problems. But she is also using LT 2008 not 2013.
The icon in the Mac tray that lauches the program is titled VMware Fusion, my mistake. We call it FusionWare because it is less awkward to say.
