Can not click on multiple objects or lines for erase,trim or extend commands. Is there a mode that I have turned on by accident , driver warning also comes up in trim offset command.
Solved by heinsite. Go to Solution.
Check that PICKADD = 1 and see if that makes a difference.
Dave.
So that others may more readily find this solution to a similar query:
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi Charles,
I've had both PICKADD AND PICKFIRST change settings on me for no reason. Is this something that is fixed with SP1?
We are waiting for our IT Dept. to "have time" to install it. We are using 2012LT.
Thanks for any info.
No there is nothing that I know off that will change these at random; though anecdotally it does happen.
Do you have any Custom Macros that you use for choosing items in a specific way?
No, I pretty much leave things alone other than the pgp file. I never had any problem with it untill we upgraded from 2011 to 2012. Since then it has happened twice with PICKADD and once with PICKFIRST. All I can say is that I would have gone nuts if it wasn't for this forum. I don't know if I would have figured it out yet.
