Hi
Does anyone know if AutoCAD LT support feature like this?! : If I have the same objects copied in different locations in design and I need to change something in this object! Is it possible that I modify the original or one of the objects and all other(copies of the one I modify) objects change accordingly?!
Solved by pendean. Go to Solution.
If it is an Attribute in a later version of LT you may need to run ATTSYNC
Or if it is a Dynamic Block that you have modified from the Palette you may need to Redfine the Dyn Blk in hte current drawing.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
