AutoCAD LT Forum
Modifying objects
2 REPLIES 2
Morussk
323 Views, 2 Replies
Modifying objects
Hi
Does anyone know if AutoCAD LT support feature like this?! : If I have the same objects copied in different locations in design and I need to change something in this object! Is it possible that I modify the original or one of the objects and all other(copies of the one I modify) objects change accordingly?!
2 REPLIES 2
pendean
in reply to: Morussk
Blocks in a single file, yes: if you meant something else you need to be less vague 🙂
Charles_Shade
in reply to: pendean
If it is an Attribute in a later version of LT you may need to run ATTSYNC
Or if it is a Dynamic Block that you have modified from the Palette you may need to Redfine the Dyn Blk in hte current drawing.
”Boost
