AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Metric/Imperial
6 REPLIES 6
derek31a
526 Views, 6 Replies
Metric/Imperial
Don't you just hate it when you pick up a drawing started by someone who doesn't know AutoCAD, yet think they do!
Simple question, and I'll probably kick myself around the room when I learn the answer - I've picked up a drawing which has been started with an Imperial Template. How do I change it to Metric, so that I can print 1:1 and not 25,4:1??
Using LT2012
See - I told you it was simple........
6 REPLIES 6
pendean
in reply to: derek31a
SCALE command and shrink it down to fix it first, then double-check known dimensions to confirm it worked.
OR
Open a template correctly set for your needs, ensure INSUNITS variable is asn you want it (usage explained in HELP), then INSERT the problem file and explode it. AutoCAD will handle the rescaling for you.
derek31a
in reply to: pendean
Thanks for that Dean.
So there is no switch I can select - either scale the whole thing (the obvious easy answer!) or start again with the correct template and paste in the original drawing.
OK, no hardship. Just wondered if it was possible any other way.
pendean
You watch too many sci-fi movies 🙂
derek31a
REALLY - I didn't think that was possible. I guess this must be life, but not as we know it.........:robotlol:
pendean
BArhoumT
not as we know it not as we know it,  lol
”Boost
