AutoCAD 2013 LT. On the ribbon I hover over Utilities, a menu drops down, I click on the measuring stick, click the first point, click the second point just like I have done 1000's of times before and I get... Nothing. What could I have done to cause it to quit measuring? All ideas, suggestions, comments will be greatly appreciated. Thanks, K.
Thanks pendean for considering and responding to my post. Apparently it's all operator error. This morning I started a new drawing and tried an F12 and received the distance in a separate window. A bit later I had to do a MIRRTEXT and change from 0 to 1. Sometimes afterward I tried the measuring stick again and it worked as I remember before the change. I went back and tried the drawing where I first noticed the promlem and it worked fine. When I checked the MIRRTEXT on that drawing it was set to 0. I tried a couple other drawings and all worked fine. The only thing that changed, or has been done differently during all this is the MIRRTEXT change to 1 on the drawing I'm currently working on. Whatever you did pendean fixed it. Thanks, K.
