AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Making NON COPLANAR LINES Coplanar?
4 REPLIES 4
wilsonta
5225 Views, 4 Replies
I'm working on a drawing emailed to me (site plan) in which lines are not coplanar so I cannot fillet, trim, etc. I would like to make the entire drawing coplanar because I have no need for it any other way! What is the command & procedure to do this?
4 REPLIES 4
wilsonta
in reply to: wilsonta
CONTINUING MY QUESTION: I used the 'Change' command, picked the whole drawing, selected 'Properties', 'Elev' & typed in zero. But, the drawing still isn't coplanar! And at the command line, it lists 'cannot change elevation of objects with differing z coordinates' & 'cannot change elevation of dimension'. Is there something else I can do or a different approach to getting all lines on the same z axis??
wilsonta
FIGURED IT OUT: You can do a search for topic ID: TS70314
Applies to: AutoCAD LT® 2000,
AutoCAD LT® 2000i,
AutoCAD LT® 2002
You use AutoCAD LT® software and have been sent a three-dimensional (3D) drawing. This means that parts of the drawing have Z coordinate values in addition to the usual X and Y coordinate values. You want to flatten the drawing so that it only has X and Y coordinate values.
Solution
To flatten the Z axis values, you can either use a procedure or one of two macros that can be assigned to a toolbar button to do the same thing.
Important
Be absolutely certain to move in the Z direction, otherwise you'll destroy the whole drawing (you can use UNDO to undo accidental changes unless you save, exit, and restart the software).
Make a backup copy of the drawing before implementing this solution.
Use a macro
These two macros move objects to a theoretical maximum distance on the Z axis and then back to the starting point. This procedure takes advantage of the way the software is designed to flatten all Z axis values to zero.
Macro to flatten a selected object:
[FlattenSel]^C^C_UCS;;_select \_move _p;;0,0,1e99;;_move _p;;0,0,-1e99;;
Macro to flatten all objects in a drawing (in the current space):
[FlattenAll]^C^C_UCS;;_move _all;;0,0,1e99;;_move _all;;0,0,-1e99;;
Use a procedure
Here is the procedure you can use at the command line:
Move
<< select all >>
0,0,1e99
Move
P(revious)
0,0,-1e99
Ask and answer your own question: I like it 😉
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"wilsonta" wrote in message
news:f105057.1@WebX.maYIadrTaRb...
> AutoCAD LT® 2000i,
> AutoCAD LT® 2002
> Solution
the same thing.
> Important
software).
solution.
> Use a macro
_p;;0,0,-1e99;;
space):
_all;;0,0,-1e99;;
> Use a procedure
> Move
> << select all >>
> 0,0,1e99
> Move
> P(revious)
> 0,0,-1e99
wilsonta
Thanks! I guess I should have researched it more before asking!!! But, sometimes asking helps yourself figure it out! If you can't figure some things out on autocad yourself, you probably shouldn't be using it! 😉
”Boost
