AutoCAD LT Forum
MIRRTEXT
2 REPLIES 2
392 Views, 2 Replies
MIRRTEXT
when using the mirrtext command on horiz. text (mirrtext system variable set to 0) sometimes the text turns upside down. is there a fix for this?
2 REPLIES 2
You are mirroring a block, not just text, and it does not work.
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
If you are using a block you can make the text right side up by typing "-attedit , then
left click the attribute, then type A for angle and enter 0 you may need to then type P to position the
attribute"
”Boost
