Is it possible to lock the attribute position within a block on Autocad LT2005. Everything i find seems to be for 2008 or later so i'm thinking not.
Solved by Kate_LT. Go to Solution.
Nope, that's a dynamic block thing. 2007 & up for LT, 2006 & up for AutoCAD.
Why would you need to Lock the Attribute if it is not a DynBlk?
And if it is a DynBlk you need tweaked just post it and someone will do so for you.
Dynamic Block Forum:
http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thought he might have found one somewhere and it needed tweaking.
I know you cannot create but you can't use them at all in LT 2005?
