I am running two networked computers and a networked Designjet 510 plotter. One computer runs LT2013 and the other LT2014.
I am having an issue with the LT2013 machine in that it plots much darker than it should (uses a heavier lineweight). I have checked the plotter set up and plot style and both appear the same.
where am I going wrong??
Solved by vaughn. Go to Solution.
All sorted.....
Default linewieg ton LT2013 machine set as .25 where as LT2014 machine set as .09. I thought a drawing would have overriddent his but you live and learn.
