AutoCAD LT Forum
Lines are not coplanar
13 REPLIES 13
Message 1 of 14
Darylt
22572 Views, 13 Replies
Tried an area command on the attached drawing but on 3rd pickpoint i get the message 'Lines are not coplanar' - this issue is only whilst using the drawing in autocad LT 2015 (working fine in LT 2014) and therefore assume that some setting in LT 2015 needs changing?
Any help will be appreciated.
Many thanks,
Daryl
13 REPLIES 13
Message 2 of 14
pendean
in reply to: Darylt
Your plan is too far away from 0,0,0, the center of the AutoCAD universe.
The file would not work in 2013 or 2015 as you noted, 2014 managed to ignore the issue for some reason.
Works fine now: it's attached, moved close to 0,0,0, and I turned on and ZOOM EXTENTS to show you what else is in your file (you need to PURGE too).
Message 3 of 14
Darylt
in reply to: pendean
Thanks Pendean - Much appreciated.
Daryl
Message 4 of 14
iharvey
Hi Dean,
Im having the same issue, and i found that your solution works, but i work with land divisions and need the coordinates far, far away from 0,0,0.
any other way around this?
thanks in advance.
Message 5 of 14
pendean
in reply to: iharvey
HPORIGIN (and HPORIGNMODE) ought to do what you need. This can also be fixed by adjusting the position of the UCS in relation to your project: if modelspace needs UCS set to World for whatever reason, you can change the UCS in the viewport which does not affect the model UCS and it regenerated correctly.
Message 6 of 14
iharvey
Hi Dean, tried both of those options but no dice.
Changing the ucs or the hatch pattern origin doesn’t fix the problem.
Can pick two points no problem, 3rd one wont select unless its far away from the first 2 (unreasonably far) and says lines are coplanar, even when picking empty space, nothing has z values.
Edited by
Discussion_Admin
Message 7 of 14
pendean
I'd love to see a portion of your DWG file with the problem in place if you can post it here. Otherwise I suspect this old limitation is not fixable.
Message 8 of 14
iharvey
Hi Dean,
sample of the file with xrefs bound in.
I know the workaround for the problem is to use polylines to generate area's, but alot of our jobs then end up going to our construction manager who views them in trueview where the problem remains.
would love a practical solution.
cheers,
Message 9 of 14
pendean
Your workaround is the corect process to use. And I don't use DTV, sorry.
I'm having a hard time locating the problem in your file...
Message 10 of 14
tomislav_vargek
that didn't work for me, but rather setting DWGUNITS to meters
Message 11 of 14
epigramx
in reply to: tomislav_vargek
What @tomislav_vargek said seems to be the issue on later versions.
Message 12 of 14
infoTYBD7
Exactly I am having the same problem, which the third point can not be selected, and  I cannot move the whole drawing back to 0,0. / ucs
Please kindly help
Message 13 of 14
pendean
in reply to: infoTYBD7
Please kindly help
Show us: share your DWG file here for all of us to access this immovable object please.
Message 14 of 14
it works changing units into meters , thanks a lot sir , i have been facing this issue almost 7-8 months ,thanks a lot for solving the issue sir
”Boost
