I frequently export drawing details into WMF format for putting into other documents.
Any GD&T symbols appear in the thinnest possible linetype when exported, and are almost illegible when printed.
I have changed the line thicknesses for all layers on the drawing.
I have changed the default linethickness, which did at least make the symbols appear thicker on the screen. However, when I export to WMF or BMP files, the symbols are thin again. This problem does not affect dimensions or text notes.
I have tried changing the DIMSTYLE and the TEXTSTYLE in the properties, and none of it makes any difference.
This is driving me crazy. Can anyone help?
Welcome to the Forums
I'm not too sure how the exporting to WMF works, BUT if you create those symbols with POLYLINES. You can set the thickness of the polyline and it will show up on your PDF as a thick line.
Howard Walker
