AutoCAD LT 2011 - Trying to transfer license to another PC. When running the license trasnfer utility the following error pops up:
Export Request Failed
The maximum number of exports for this serial number has been reached, You may not export more licenses than you have purchased.
Click the "Try Again" link to resubmit the request.
Try Again
Error Reference: 36
I don't think this license was ever transferred previously. If so, I thought you could transfer an unlimited amount of times using utility.
Some info:
License name: AutoCAD LT 2011
License Type: Standalone - Locked
License expiration: None
License behavior: Permananet
License usage type: Commerical
License ID: ACDLT_F_S
Solved by philip.s. Go to Solution.
But only if you transfer back again.
The idea is to allow you to use one License on multiple computers.
You may install the program at work, home, laptop and move the License to each of these one at a time so only one is ever being used with one License.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Confirming what Charles and Dean stated above.
In this case, there was an open export as it was never imported back onto another machine, prevent an additional export as the open export count can't = seat count which in this case = 1.
hello, im having the same issue, im trying to export a license to upgrade the machine but get the errorcode 36.
Is there something about the responses already posted that you did not understand? You can export a license that's already exported/checked out.
Just like at the city book library, you can check out a book that's gone and not there.
Put it back first: you or someone else already exported the license previously. You not knowing about it is sadly of no use to anyone. Or you can install and reauthorize the software all over again on the new PC: that's always an option unless you are on a student license.
I am working a refresh today which involves an AutoCAD license transfer, which I have worked before, but this time I get an error when working the transfer, The user has AutoCAD LT 2011 and we are looking to export the license from the old PC to then import it on the new replacement PC.
but when doing the export fails Error 36
However the solution above does not make sense regarding the issue we have. Since to use the quote (in the attached page) the book is there on the original PC. It is useable thus should be available to export.
Are you able to assist please?
Hello penden,
I have already posted this AutoDesk cryptic License Utitlity Transfer - Error reference: 36 (error) message on the AutoDesk Community boards. So, I do apolgize if this has already been addressed. As of today's date (Sept. 14, 2014), it has not been addressed. Yes, patience is a virture.
If I follow your analogy about "checking-in" and "checking-out" a book from your local library, I checked-out (exported) my AutoCAD 2012 standalone/student license when I wiped out my Windows XP OS on my current computer. I then checked-in (imported) my license, when I installed my Windows Vista OS on the very same computer. Now, I'm trying to do the very same "export - import" procedure but with my new computer.
I don't know if I should ignore the LUT error message (because on another AutoDesk Community board, the LUT application has been deemed as unreliable) and do a standard installation on my new computer or just wait for an offical response from an AutoDesk-AutoCAD designated "expert" to give me an official response on how to respond to this error message.
These are details of my AutoCAD 2012 license:
[Product Information Properties]
Thursday, January 02, 2014 10:10:27 AM
License name: AutoCAD 2012
Computer host name: LENOVO-CA8585B6
Product serial number: XXX-XXXXXXXX
Product key: 001D1
License type: Standalone - Locked
License expiration date: None
License behavior: Permanent
License usage type: Student Version
License ID: ACD_F_S
I bought this license and registered it with AutoDesk. So, I should not see why AutoDesk will balk at my request to transfer this single, standalone license to my new AutoCAD-compliant computer, since this is a simple export/import procedure despite what the LUT error message says.
Thank you for your help in this issue,
Darren Murphy
In my opinion there is an error in LTU (with all the respect). I have been trying to do it many times on different computers with AC LT 2012/13/14 and it always was working like a charm. Suddenly last year problems started and at the beginning there was a chance to try few times to get success, now there is no way to transfer anything no matter how many times you try.
I've just tried to export AutoCad Mechanical 2015 licence as user has got newly installed computer and I could not do it. I got error 36 and I'm sure nobody could transfer this licence, on old computer AutoCad worked without any problems. We installed SW on new computer with old codes with success and we still can run SW on old computer 😕
Of course on old computer SW will be de-installed but for sure LTU does not work like it should reading library example.
I find this system very confusing. I wish there was a central place in the "Autodesk Account" web portal where a user could view all current activations of a license and disable them. I am currently trying to upgrade my workstation and laptop to windows 10 and am recieving error 36 when trying to export the license.
I believe it is because the "OTTO" virtual chat bot has generated a new activation for me on one of the machines before I went and deactivated the existing one. I just wish I could simply deactivate all licenses and get back to work again like with Creative Cloud. I suppose that would require the machine phoning home on every launch of the App, which users would hate.
If you tried transferring the license from one system to another but the license doesn't get downloaded onto the new machine or uploaded to the Autodesk Cloud, it's due to one of the following:
That being said, once those issues are corrected on the destination machine (serial number, or software mismatch), you should be able to copy down the transferred license.
If after making the changes still doesn't work, just activate the software on the destination machine.
Note: If you activate the new machine, make sure you uninstall the software from the old machine along with deleting the following directories:
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
