If you put the V-Port Window in "Model", open Layer Manager, you can freeze
layers for that V-Port only on the right side under Current View.
Don't forget to change the V-Port back to Paperspace.
TLS
wrote in message news:4934840@discussion.autodesk.com...
Hi Folks I don't know if this has been posted before, apologies if it has. I
have a drawing which has several x-ref's and set up in paper space with a
number of Viewports.
I have tried to control the drawing using Layer States. This works for
layers which have been turned off, it will restore them no problem, but if I
freeze the layer in the Viewports it doesn't work.
What is going on? Has anyone ever come across a similar problem?
Any help would be appreciated.
Emma
