When you have a printer specified and do not have it on and go to create a layout you will get stuck in loop hell.. with a dialog box that says "AutoCAD LT Error !! There is a problem with selected device. !!"
This should not happen.. as an option is to cancel and you can not ... i had to CTRl alt delete and kill the prog from task manager.
Not Good!!!!
Coming from a "Expert Elite" that is a rude response... Why do i turn my printer off you ask... its my prerogative to turn the thing off If i want to. It's my printer I paid for it I pay the electric bill for it I buy the Ink for it i'll turn it off if i feel like it.. get over it Dean.
What we shoud really be asking is why is it that AutoDesk cant get it right out the box in the first place... I remember a time when they did... here lately not so much.
Do the world a favor and read what you write before you post.
What are the Printer, OS, and LT version?
Here I am using an HP Designjet 800, Win 7 Pro, and LT 2014.
If the printer is not on nothing happens. The prints just sit in the queue until such time as the printer is turned on or the computer is turned off. (Wondered what was coming out form time to time when I forgot.)
Never seen the loop occur in nearly 20 years of working with LT thru various versions or OS.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
if you reread my post I didnt try to print anything... I created a layout tab which was trying to default to a printer that wasnt on or needed at the time.
nevertheless..when you press cancel it should cancel the operation not get stuck in a loop.
This is clearly a bug and will be reported as such as it also happens in vanilla acad 2014.
Thanks for your suggestions.. hopefully they will help someone else as a work around that encounters this issue.
