This issue has been an irritant for a few days and today is almost constant. When I do a quicksave the program hangs up and I get a Program Not Responding message. The panels all go white and the desktop is ghosted like there is a film across the screen and I have to wait 2-3 or more minutes for things to resolve. Any ideas anyone?
Typically we save to a network drive, but I have also tried saving to my desktop with the same results. The entire program is sluggish. I have tried opening a series of small drawings and each one, on the network, results in a Not Responding message and takes several minutes to open.
I downloaded an update this morning to see if that would help, and have rebooted twice but the problem seems to be getting worse.
If you unplug from the network and try opening a file, is the problem still there?
I don't know, how do you unplug from a network? This is an office computer and I dont' know if that is under my control.
To unplug from the network, all you have to do is pull the network cable out of the back of the computer. Do you know if you've had any automatic updates to your system since this started happening?
The IT guy is looking into this. He thinks it is a problem with how the VM Fusionware is interacting with the program. I am working on a Mac Pro desktop running OS X and Windows.
And yes, I did download an update yesterday, and rebooted twice.
Ah I'm afraid all the users here use Windows PC.
If you click on the link below it will take you to the Mac forums, and they should be able to give you more help there.
Howard Walker
Technially I am on a PC, the IT guy worked on things yesterday and had me set the Workspace Settings to 2D Drafting and Annotations which seems to help a bit. He also increased the memory.
Now the issues seems to have settled down to problems when I use Quicksave. I hit Command+S, wait a few seconds for the save to finish, the cursor changes to an arrow and stays. When I click on the drawing it freezes up for 30-60 seconds, panels go blank and the header has (not responding) next to the drawing nam. Then the cursor changes to to cross hairs and all is normal again.
The command line says Quicksave when I save in LT 2013.
So why did this start happening? I had made no changes to my system prior to the problem onset.
When I asked before if you had any automatic updates recently, I was not talking about downloading the service pack for autocad. I was refering to windows updates that seem to come everyother day. I'm not sure if that happens with your setup using a macbook but I had probably 20 different updates this past weekend from Microsoft. It didn't mess with autocad but it did hose up my internet explorer. They have been known to cause problems with autocad though so that might be something to have your IT check on.
Thanks for the link and article. I turned off Windows automatic updates but the IT department is going to have to figure out how to fix what Wilndows hath wrot on my computer. That would explain some of the issues with other programs.
