Show only
Search instead for
When I start up LT2008, I get a blank screen, but by menu is not laoding (it used to). I have to open the <File> tab and the it has an menu option I can them load my .cui menu
I tried that, no avail... I talk about when I start AutoCad there is nothing there, toolbars are gone.. I have a custom menu system I designed, it used to load whenever I started it up, now i have to go in and manually load it each time.
CUILOAD command, load your custom menu file, then save your active workspace: unless you have some customized startup shortcut that is sabotaging LT that is how it works.
