AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Inserting raster images
11 REPLIES 11
Message 1 of 12
348 Views, 11 Replies
I'd like to know if it is possible to insert (attach) raster images in
AutoCAD LT 2002 (spanish language if this makes a difference).
Reference guide is ambiguous, it suggest it is possible but does not show
how.
Online Help says it is, via "Administrador de Imàgenes" (Image Manager?) but
opening it everything is greyed, and the "Enlazar , desenlazar" (attach ,
unattach?) buttons are missing, I see how it can manage images already
attached using full featured AutoCAD, but it would seem either it can not
Attach new images or I am just missing how.
thanks much
Fermí
11 REPLIES 11
Message 2 of 12
Fermi,
From the help file
"You must use AutoCAD to insert or manipulate the images in an AutoCAD LT
file, including attaching and detaching them."
I thought you were a viz guy 🙂
-joe
"Fermí Bertran" wrote in message
news:A2D6D2D55B8BBE6DB997274A51EA3507@in.WebX.maYIadrTaRb...
> Hi,
> how.
but
> thanks much
> Fermí
Message 3 of 12
Thanks Joe,
spanish Online Help SAYS you can " Enlazar y desenlazar " ( attach and
dettach ) image files, it must be a typo... bit anoying typo though.
Yes, I am basically a Vizer :o)
If we were to be in the VIZ NGs I'd go to vizions and attach some screen
grabs :o)
but also a stubborn workarounder (if such a thing exists), found one
(workaround), minimal initial help from an full featured AutoCAD needed:
If you happen to have a file that already has a raster file attached (any
raster fiel, a single pixel will do).
Inserting that file in AutoCAD LT 2002 will bring the image into LT, since
the manager is fully operational, then you can change the path, name,...
etc.
;o)
Fermí
Message 4 of 12
The attach button in the Image Manager is only available in AutoCAD, not LT.
But someone forgot to remove the short cut key.
Use IMAGE command to get the Image Manager.
Then press CTRL+A to fool the lost Attach button :o)
Conny
"Fermí Bertran" skrev i meddelandet
> Hi,
> how.
but
> thanks much
> Fermí
Message 5 of 12
Did I say "CTRL+A"? Make that "ALT+A"
Oh, I bet you use the spanish version of LT?
Then this tirck might not work.
Try some possible shortcuts for Attach in spanish.
Conny
"Conny Klasson" skrev i meddelandet
news:6FCDB6A3305110EDF7FDE8C57580298D@in.WebX.maYIadrTaRb...
LT.
> Conny
> > Hi,
show
> > how.
> but
not
> > thanks much
> > Fermí
Message 6 of 12
Thanks Conny,
The shrotcut is not working for me CTRL+A (I am using spanish version of the
software) this may be because shortcut is a different one (don't have acces
to AutoCAD 2002 spanish to check what the shortcut would be, have tried
ctrl+E (enlazar) and some other letters without succes)
May be they "fixed" the feature in the tranlsated version, or may be it's me
who is underfeatured :op
Anyway, the "insert dwg" workaround is working for what I need :o)
At least until the workaround is also fixed :o(
cheers
Fermí
LT.
Message 7 of 12
Hi Conny, you are GREAT!!!
To all spanish users ALT+E will do! ehehe
You have just added some value to my software :o)
Fermí
Message 8 of 12
Too bad QE will likely monitor the NGs and they'll likely use the scisors in
the next release, or may just be we are lucky,and they are hardly bussy at
someotherwhere :op
Fermí
Message 9 of 12
Then you owe me a beer!
Conny
news:23CD450E72D4F64292319B6AFE39EA62@in.WebX.maYIadrTaRb...
> Fermí
Message 10 of 12
Well, I saw this here in the NG so it's too late already.
Then you don't owe me anything after all :o)
Conny
news:B64B261C99152E06E1188BC7D03E9038@in.WebX.maYIadrTaRb...
in
> someotherwhere :op
> Fermí
Message 11 of 12
If we ever manage to organize a european viz users meeting (or you happen to
come to BCN) you'll have your beer :op
not in my plans going to sweden soon, I apologize
Fermí
Message 12 of 12
I see SlingShot has already been mentioned. It works well. And so it
should....it's an Aussie product from what I can tell.
Go Australia in the cricket today....!!!!
Ric Norris.
http://users.bigpond.net.au/cavedrawings
> Hi,
> how.
but
> thanks much
> Fermí
”Boost
