AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Image Obscuring Vectors
7 REPLIES 7
Message 1 of 8
StoneEdgeFarm
542 Views, 7 Replies
Perhaps this is two problems but I am not sure so here is what is happening. I have a dwg with a background image path that is no longer valid. It is not apparent or not allowable to edit the path to the image file. So unable to edit the path, I detached the image and reattached it from the new path location. When I do this the image obscures all the preexisting lines in the drawing. Either I need help revising the path to external image or I need help to push the image to be behind the vectors.
Any help appreciated.
Mike
7 REPLIES 7
Message 2 of 8
drjohn
in reply to: StoneEdgeFarm
Should be a frame around the image.
Type in DRAWORDER at the command line (or select from a menu or ribbon) and select the frame around the image when prompted.
Send it to the back.
HTH
DJ
Message 3 of 8
pendean
in reply to: drjohn
... or using DRAWORDER you bring everything else forward/on top of the image.
Where did you try to repath the image' location? LT version?
Message 4 of 8
Yes, thanks for suggesting the Draworder command. I had tried it earlier but I must have done something wrong. It worked perfectly this time and I was able to reattach the image.
Problem solved.
Thank you for the help.
Mike
Message 5 of 8
drjohn
DRAWORDER does not always work as expected. Smiley Frustrated
Have a good one.
DJ
Message 6 of 8
bgingerich
in reply to: drjohn
I've always found that if something doesn't look right, a regen normally puts it all back.
Brandon Gingerich
Message 7 of 8
drjohn
in reply to: bgingerich
Especially with blocks.
Message 8 of 8
pendean
in reply to: drjohn
... and hatches.
”Boost
