You might not want to wholesale copy all your LT98 menus and stuff to
LT2002, as enough have changed and a lot was added to LT you would not have
a good time.
If they are not, you need to set up your LT98 menu as an add-on, then you
can use LT's MENULOAD command to load and add your menu to the existing
screen menu. Just make sure all the new toolbar button image files you might
have created also get moved. The Support folder in the LT2002 folder is a
good place to drop them (just do not overwrite anything already there).
If you have custom linetypes, and hatch pattern files, even more work is
involved: HELP can explain most of this, but you need to post more
information like are you just looking to move some custom toolbars, do you
have any custom macros, custom toolbar images, custom linetypes, custom
hatch patterns, special file search paths you need to maintain, did you edit
the main LT98 menu files, or did you create and add a custom made one etc.
Dean Saadallah
www.pendean.com
"dla_001" wrote in message
news:f0ac751.-1@WebX.maYIadrTaRb...
> What do I need to do to transfer my LT98 customizations (button-bars,
menus, etc.) from LT89 to LT2002, assuming I want to install 2002 >over< 98?
The default installation doesn't seem to respect 98's customizations...
> Thanks in advance...
> David
