AutoCAD LT Forum
How to end the "select objects" part in a script?
4 REPLIES 4
Coooper
5475 Views, 4 Replies
Dear Forum,
I am trying to write my first script in AutoCAD LT 2014 and got stuck. I can not find an answer anywhere for the problem.
The script is supposed to
- open a certain block in the block editor
- delete some information from a block,
- change a property of an object within that block,
- then close the modified block
- then select this modifed block plus some other blocks with the help of "FILTER"
    (requiring my user input in the dialog box)
- and in the end explode all those selected blocks
My script is workling fine, except for the step where I want to execute the "explode" command over the objects selected via the "FILTER"
This seems to be because the selection is lost before the "explode" command is applied to the selection (see command history for this script)
Here's the script:
-BEDIT
Floor
_-BVSTATE
_s
ATT
erase
window
50,950,0
1300,-2292,0
chprop
window
-50,1050,0
1050,-50,0
la
Layer 2
_BCLOSE
Filter
All
explode
______________________________________________________
Here's the corresponding command hisory:
Command: _SCRIPT
Enter script file name <C:\BlockTEST.scr"
Command: -BEDIT
Enter block name or [?]: Floor
Regenerating model.
Command: _-BVSTATE
Current visibility state: FF
Enter an option [New/Set/Delete] <New>: _s
Enter visibility state name to make current or [?]: ATT
Command: erase
Select objects: window
Specify first corner: 50,950,0
Specify opposite corner: 1300,-2292,0
28 found
Select objects:
Command: chprop
Specify first corner: -50,1050,0
Specify opposite corner: 1050,-50,0
1 found
Select objects:
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: la
Enter new layer name <0>: Layer 2
Command: _BCLOSE
Enter option [Save/Discard changes] <Save>:
Regenerating model.
Command: Filter           (here I get the "Filter"-dialog box to manually select an existing filter)
Applying filter to selection.
Select objects: All
2 found
Select objects:
Exiting filtered selection.       (why is the selection not kept acrtive so "explode" is applied to them??)
Command: explode              (because if I simply end the script: Filter
        All
Select object: *Cancel*
_______________________ ... without the "explode" I end up with the correctly selected blocks,
                                                  ready for me to "explode" them by hand)
I tried all combinations I could think of in this last step:
- with two "returns" to end the slection process           ->  FILTER is repeated, no success
- with "explode" directly after "All", so no empty line   -> selection is lost and command history reads:
        Command: Filter
        Select objects: All
        2 found                         (yes! correct until here)
        Select objects: explode
        *Invalid selection*
and others.
I can get this to work using a macro with this content:
^C^C-bedit;Floor;_-BVSTATE;_s;ATT;erase;window;50,950,0;1300,-2292,0;;chprop;window;-50,1050,0;1050,-50,0;;la;Layer 2;;_BCLOSE;;filter;all;;explode;
I guess it is not pretty, but in the end that one block is modified and then exploded together with the other blocks.
Very much looking forward to your help!
4 REPLIES 4
pendean
in reply to: Coooper
scripts do not control pop-ups, never have, still don't. This applies to when you are done with pop-ups too. No fix.
Coooper
in reply to: pendean
Hello pendean,
thank you for the clear, yet saddening answer.
I will work with scripts and macros some more to get a better understanding of the possibilities and limitations, but while we're at it: Is there an easy answer on why my automated procedure works when I translate it into the macro? Can macros control pop-ups?
pendean
macros, like scripts, do not control pop-ups or what happens after a pop-up is closed.
If you need to automate, consider stepping up to full AutoCAD with it's full power coding/customization ability (allows you to skip/circumvent pop-ups).
In your case, would SELECTSIMILAR be an option instead of FILTER? Don;t forget about SELECTSIMILARMODE variable that controls the options you may want. Test and find out.
Coooper
I will try if I can use the SELECTSIMILAR command to my advantage.
Thank you for the help!
”Boost
