Solved by cdavis7254. Go to Solution.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Command: MVSETUP |option> Align |option> Rotate
click north to south or east to west etc... pending on the direction you would like to orient you view, best of luck.
Command MVSETUP is not available in LT.
Yes that is true, but hopefully this will help someone who does have the full version, since this page is all I could find, I put the answer here for any one else that did not know, like I did not know!
I admire your tenacity to help others but it can also be useful to inform those who may come across this in the LT Forum that this feature is not available to them thru at least the 2011 release.
Solution:
- Create a view with MView and Polygonal with 4 points
- Rotate the total View on user asked angle
- Create new square
- Replace the 4 points on the square
- Remove square
- Ready
Well this works for me
