Hi, without knowing i pasted a furniture block from a Student Version into my licensed AutoCad LT... now it's printing with the student version watermark... any ideas how I can revert back to normal printing? The student Version was on a removable disk and not even installed on the machine... Please advise. Thank you.
Hi, i'm new to LT and didn't not get a warning... Will definitely turn it back on. Do you know if reverting is actually possible? I tried googling it without any luck. Any help is much appreciated. Thank you.
You will need to contact a reseller in your area or try and remove all the infected files from your system.
Delete the block immediately. You can use ADCENTER to Search for this Block in each drawing to find all instances of the block.
And delete those drawings as well.
Find a reseller.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
