I have a model dwg that is in color, once I place in paperspace it is still in color, but once I pdf documemt it only pdf's in black and white
Any suggestions
Solved by Charles_Shade. Go to Solution.
Click on the Layout tab so it is active.
Right click the Tab and bring up Plot... dialog
In the upper right corner under Plot Style Table set it to None. (If you do not see that click the heavy arrow in the bottom right corner to expand the window.)
Below that also check Plot with Plot Styles.
That should give you a color PDF.
Longer term fix is to use the Page Setup Manager and set the LAyout to the settings you want.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
