All lines in model space appear thicker when I zoom in.
Can you remind how to change this behaviour so they show the same weight thin in the computer window?
Thanks in advance.
Solved by hwalker. Go to Solution.
Which version of Autocad are you using?
In LT2009 at the bottom left of the screen is a row of icons. One of them is 'Show/Hide Lineweight'. Make sure that is not selected.
Howard Walker
