AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Hatching
4 REPLIES 4
derek31a
406 Views, 4 Replies
Hatching
LT2012
When I move a hatch boundary around unassociated hatch, it leaves the hatch pattern behind. If I then pick the hatch the grip points become available so that I can move the hatch to the new boundary.
The problem is that often the new boundary has a few more bends in it - SO, how do I add extra grips to the hatch to follow a new outline rather than redefine it from scratch? Is it even possible?
I await a response with baited breath.........
TIA.
4 REPLIES 4
rkmcswain
in reply to: derek31a
I don't have 2012 in front of me, but does the hatch object have the rectangle grip at the midpoint between the main vertices of the hatch object, as shown here?
R.K. McSwain     | CADpanacea | on twitter
derek31a
in reply to: rkmcswain
Thanks for the response.
Yes, the mid-point grip is there.
Using your 5 sided example, what if you turn it into a 7 sided figure - that's what I'm trying to do in essence, only on a larger scale hence trying to avoid starting the hatch process again.
Many thanks
rkmcswain
Use the Add Vertex option to add vertices.
Use the Convert to Arc option to do that (if the segment is already an arc, it will say Convert to Line)
derek31a
Ho-Humm
I saw your example, but didn't see it - I missed the menu that said add vertex.
I've never noticed it before, guess I don't hover enough!!
Anyway, does exactly what I was looking for thank you.
Kudo on the way!
”Boost
