Model space and paper space are truly two separate environments. As of
AutoCAD (and LT) 2006, the only associativity between the two is with
dimensions.
My suggestion is that you have another look at your process. Is there any
way you can do what you're attempting to do between the two spaces all (or
even mostly) in one or the other?
Dave Byrnes / Vancouver, BC
Autodesk Discussion Group Facilitator
wrote in message news:4963690@discussion.autodesk.com...
I have been trying to resolve a way to have a pline, hatch, anything that
can be used as reference line in paperspace to be on top of the hatched
areas from model space. Draw order does nothing, the solution has been to
put that pline or whatever else in model space too and then draw order it on
top.
We have hatched walls in model space that are showing up on top of the
lines that are trying to reference a section cut and are at a loss to have
the paper space line be on top.
We don't want to have the information in m.s., for consistency sake we want
the text and reference lines on paper space.
if you have any idea how to remedy this in any way please reply.
Thank you kindly.
CHM
Kelly Architecture and Planning
California, USA
916-797-1199
