AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Geomcal substitute in ACAD LT
4 REPLIES 4
193 Views, 4 Replies
I have used full-blown AutoCAD for several years and have just recently
started LT. Is there some way of accessing Geomcal type calculations in
AutoCAD LT?
I have two line endpoints and would like to find the midpoint between the
two. With geomcal, I would:
Command: line
Specify first point: 'cal
function: mee (mid,end,end)
I would then be able to select the two endpoints and it would start my line
halfway between them. Is there some way I can do this in LT, or do I have to
place a construction line between them and select the midpoint and then
erase the con. line when I complete the line I want?
Thanks for any help.
Ray Thompson,
caduser@bigfoot.com
4 REPLIES 4
"R. G. Thompson" wrote in message
news:3B3316A8E91D8E67FD566E272ED7A7A7@in.WebX.SaUCah8kaAW...
> AutoCAD LT?
For this particular application, you could use this macro [Join at & remove
"+" for toolbar button]:
^C^C_line;_end;\_end;\;_id;_mid;\+
_erase;_last;;_line;@;
Basically it's what you'd do manually. Draw a line from one endpoint to
another, select the new line's midpoint, erase the new line, and finally
begin another line from the midpoint you found.
Enjoy,
Stef
mailto: yodersj@ipass.net || Drafter, Leather-worker
http://www.ipass.net/~yodersj/ || Dos, Win, LT
in progress: http://computerhowto.homestead.com/
RFC 1855, section 3.1.1, item 10 at http://www.faqs.org/rfcs/
Basically, there is no 'CAL option in LT.
If you need such a thing, as Stef suggested, you spend the time and write
every conceivable simple variation you need in DIESEL macro language, or get
back to full AutoCAD.
Dean Saadallah
www.pendean.com
"S. Yoder" wrote in message
news:72D7D829745F231E5ADD188FE2BCFB7B@in.WebX.SaUCah8kaAW...
> > AutoCAD LT?
the
remove
> Enjoy,
> Stef
Ray, you can program you own CAL-type functions using DIESEL. An
example for a mid-like snap is in the DIESEL documents on my site
www.crlf.de
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Webmaster, AutoCAD Developers Group Europe, http://www.adge.org
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
Dietmar Rudolph wrote in message
news:mjht5tol4vothrmsmmvfvbe0jbhem6ff6h@4ax.com...
> www.crlf.de
> Dietmar Rudolph
Hi Dietmar,
It's been probably 4 - 5 years or so since I've looked at your website but I
do remember that your explanations and examples were most helpful when I
first started tackling this DIESEL thing.
P.S. Weren't you a CompuServe regular? I sure do miss the CS AutoCAD forms
though I'm not complaining. Anyway, please check out my website if
you get a chance. Over 5 years in the making (software, that is - website
about 3 weeks). I can't believe I'm finally finished! I'm all DIESELed out!
Thanks allot,
Mark Gonzales
www.lt-solutions.com
”Boost
