Basically, there is no 'CAL option in LT.
If you need such a thing, as Stef suggested, you spend the time and write
every conceivable simple variation you need in DIESEL macro language, or get
back to full AutoCAD.
Dean Saadallah
www.pendean.com
"S. Yoder" wrote in message
news:72D7D829745F231E5ADD188FE2BCFB7B@in.WebX.SaUCah8kaAW...
> "R. G. Thompson" wrote in message
> news:3B3316A8E91D8E67FD566E272ED7A7A7@in.WebX.SaUCah8kaAW...
> > I have used full-blown AutoCAD for several years and have just recently
> > started LT. Is there some way of accessing Geomcal type calculations in
> > AutoCAD LT?
> > I have two line endpoints and would like to find the midpoint between
the
> > two. With geomcal, I would:
> For this particular application, you could use this macro [Join at &
remove
> "+" for toolbar button]:
> ^C^C_line;_end;\_end;\;_id;_mid;\+
> _erase;_last;;_line;@;
> Basically it's what you'd do manually. Draw a line from one endpoint to
> another, select the new line's midpoint, erase the new line, and finally
> begin another line from the midpoint you found.
> Enjoy,
> Stef
> mailto: yodersj@ipass.net || Drafter, Leather-worker
> http://www.ipass.net/~yodersj/ || Dos, Win, LT
> in progress: http://computerhowto.homestead.com/
> RFC 1855, section 3.1.1, item 10 at http://www.faqs.org/rfcs/
