Please suggest me some good links for freelancer jobs of AutoCAD LT. I searched for it and found that jobs are available for Solidworks, pro-E & AutoCAD full version. These jobs are totally based on 3D. My system only supports AutoCAD LT hence can't take AutoCAD Full Version jobs. I can do mechanical (with scaling), electrical and electronic (without scaling) drawings in AutoCAD LT. The websites which I searched are Elance.com and freelancer.in. Please find the samples of my work as attachments in bitmap.
Thanks in Advance
There are many job-seeking websites you can post and search in, and you can also explore this forum site:
Btw OP your system WILL support full AutoCAD...
I was informed earlier in the AutoCAD Forum that I need atleast 8 GB RAM for smooth functioning of AutoCAD Full Version which my Motherboard doesn't support.
Pish tosh! I still have my old similar PC, and it was running AutoCAD 2011, full Revit Architecture (educational), Inventor (educational), SolidWorks, sketchup plus a few others...
4Gig is 'good enough' as long as your harddrive is not over 75% full, and you enjoy occasional long coffee breaks between large file saves and 'open' functions 🙂
And a good graphics card that does not pull from system resources
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
That may have been mis-heard, or passed on from a mis-communication. You are running a 32-bit operating system and 32-bit software which won't take advantage of the additional RAM. Thats different than the motherboard not supporting it. Most laptops produced within the past half-decade will readily support 8 GB RAM (usually more), and certainly any recent desktop will support anywhere from 12 - 32 GB.
