AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Export points as text or ascii file
4 REPLIES 4
montanorugebregt
2869 Views, 4 Replies
Can AutoCAD LT 2009 export points as an ASCII or text file retaining the XYZ attributes? If so how do you do it? Edited by: montanorugebregt on May 6, 2009 5:15 PM
4 REPLIES 4
in reply to: montanorugebregt
Only if each of those points was a block: are they?
Dean Saadallah
http://LTisACAD.blogspot.com
thank you so much for the reply.
The points are not blocks. How can I make them a block for each point?
Could you tell me the steps I need to follow just for one point, how to create a block, then how to export it.
Thank you
Montano
it's not that quick.
You create a block using BLOCK command, with an
ATTRIBUTE: content is a POINT of course. All three items are explained in
Help.
You INSERT the block at every location you have a
point.
ATTEXT is the command you can use to start setting
up your spreadsheet "text" file. Also explained in Help. It requires some setup.
Use the OBJECTS selection option.
cjwagner
So if I understand this correctly ... I can go to cusotmize user interface select geometry x,y,and z points, click on each point, and see each X, Y, and Z point but cannot export that information out to a file for multiple selections? In LT of course.
CJ
”Boost
