I just got AutoCAD LT 2009 and have not been able to get it to work. I have been having numerous errors during startup of the program. My computer is a brand new (less than 2 weeks old) dell precision laptop running XP SP3. I have searched for a solution that would work and as of yet, nothing has. Right after I installed the program I got an error:
"The type initializer for 'MS.Internal.Classification' threw an exception"
The only option was to continue. After that the program would crash immediately with an error to the effect of
"unhandled access violation reading 0x000c exception at 55566b2dh"
This would happen when I would try to click on the top menu bar. I eventually downloaded the 2.01 patch and installed that. After I installed the patch I would get the error that "AutoCad had not been installed properly and that features would be unavailable." It would still crash when I went to the menu bar. I did a complete wide of autocad as per the [http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2887771&linkID=9240617] Including the registry edits. I re-installed and had the same problems. I then found that it could be a problem with the MS .NET framework. So I then uninstalled Autocad and all of the frameworks that were on my computer. I then re-installed framework 3.0 as per [AutoDesk Support Site,|http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7236884&linkID=9240617] then re-installed Autocad from another complete wipe. I still have the exact same problems. I have also done multiple virus sweeps to make sure that there was nothing else that may be giving me grief. There were other people that had a problem with the W32.PINF virus, however that is not on my computer. I am getting quite fed up with this program and I have not even been able to draw a single line yet. I have been trying to get this to work now for the past 3-4 days to no avail. Is there anything else I can try before i throw the disk out of my window?
Edited by: jtornquist on Dec 16, 2008 7:11 PM
