AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Enhanced attribute editor by defaut, how to change it ?
1 REPLY 1
c.dufrene
6349 Views, 1 Reply
Hi, By defaut a double click on a attribute opens the "enhanced" fonction. I don't want this, I want the "normal" attribute editor, is there a variable to change ? Or another way ? Thanks.
1 REPLY 1
pendean
in reply to: c.dufrene
Do you mean you want DDEDIT command instead of BATTMAN command?
CUI command's pop-up stores all the double-click actions: change the default under ATTRIBUTE BLOCK and ATTRIBUTE DYNAMIC BLOCK from EATTEDIT command to DDEDIT command. You do this by deleting the definition at each location and replacing it from the list below.
Just be aware of what you are giving up in the process as far as features go.
”Boost
