AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Editing Issues with 2010 LT
3 REPLIES 3
mwilk
259 Views, 3 Replies
I have been using 2010 LT for a few months with no issues, but suddenly I cannot edit text, dimensions, and lines as I did before. I used to be able to select the item I wanted to edit, then right-click and copy, paste, scale, etc. To edit text, I used to be able to double-click the text and I could retype what I needed. Now when I double-click on text, nothing happens. It appears locked, even with multi-line text I had just created. When I select dimenions or lines, I can no longer right-click to make any changes.
Anyone else have this problem?
3 REPLIES 3
Charles_Shade
in reply to: mwilk
When did this start? What changed on your computer? Did Windows do an update? Was a registry cleaner run? Has a new program been installed?
Regards, Charles Shade
in reply to: mwilk
PICKFIRST variable, look it up in Help.
Dean Saadallah
http://LTisACAD.blogspot.com
mwilk
in reply to: mwilk
PICKFIRST Variable fixed my problem. Thanks a lot!!
”Boost
