AutoCAD LT Forum
Dynamic block with alternating objects
2 REPLIES 2
Chris
406 Views, 2 Replies
I'm currently creating blocks for our office library. One of these is a grille with some apposed blade dampers on it. I'm trying to set up an array that will duplicate the apposed blades as I change the length of the grille. However, it will only copy the blades in pairs, not singlely one after the other. Ie, the blades are 100mm apart, and in a / \ pattern meaning that each instance of / or \ 'should' duplicate every 200mm. Except when I lengthen the block by 200mm it won't duplicate untill I've gone double the distance (400) when it gives me both / and \.
Does anybody know of any solutions? Or if it's possible?
2 REPLIES 2
maxim_k
in reply to: Chris
Just now I have no opportunity to test your block and I think it is better to post your question here:
forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
You will get better and faster response there.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Chris
in reply to: maxim_k
Thanks, good point. I'll post it there. I found a similar post via Google and just posted in the same forum without checking...Whoops.
Cheers,
Chris
Sent from Samsung Mobile
”Boost
