What I have found to be the most successful for the creation of jepgs for
the is...
Use a pdf creator program such as adobe acrobat (comes with a pdf printer),
win2pdf, ect... with the dpi set at 600 dpi.
Once I have a PDF file I then export it out using adobe acrobat (not reader
but full version) and I get the results similar to the above...
Jeff
"Dean Saadallah" wrote in message
news:5893338@discussion.autodesk.com...
You zoom in to the max possible, then you play around with DPI settings to
get the resolution you seek. beware of huge files being created...
Understanding dpi resolution with the Raster File Formats HDI plotter driver
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2880522&linkID=9240617
and
http://www.dotsoft.com/procedures.htm#PlotToRaster
or
PLOT to PDF, PNG, JPEG, BMP, PCX, TIFF, PS and EPS for free and with more
control over output using:
http://sourceforge.net/projects/pdfcreator/
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
