Before beeing helped here are the configuration of my PC :
DELL (2003)
Operating System : Windows XP
My question :
After having downloaded AUTOCAD LT 2012 (trial version), just at the full end I had this message (excuse me it's in french) :
Erreur 1606.L'emplacement rĂ©seauMes images\ n'a pas pu ĂȘtre atteind.
or in English (may be with some syntax error from me) :
Error 1606. The place link my images\ could not be connected.
If some body knows the problem and have allready discover this message, thank you to explain me how to manage to obtain the correct issue.
Best regards,
Hughes.
Solved by Charles_Shade. Go to Solution.
Error 1606 from Knowledge base
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. â
Thank you for your mail, I did a kudos and I clicked on accept.
If you have any solution I want well be oriented,
Best regards,
Hughes
