I had this happen once on a customers drawing. Basically there was
corruption in the drawing. To fix the issue wblock out only the good
parts of the drawing and then inserted the wblock back into a blank
drawing. Being selective about what you place in the wblock will be
important here.
Melissa Leggee
Autodesk Product Support, Platform Technology Group
Discussion Q & A: http://www.autodesk.com/discussion
rferry wrote:
> In one of the files I'm working on, the gravel hatch has simply
> distorted itself with any new creation. A correct pattern can be
> created in another file and pasted in without distortion, placed side
> by side with the distorted hatch. Matching the properties of the
> correct hatch to the distorted hatch does not fix it, but matching
> properties from the distorted hatch to the correct one will distort
> the correct one. The .pat file is fine and works perfectly well in
> other files.
> Any ideas??
