AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Display driver file is missing or corrupted
11 REPLIES 11
Message 1 of 12
35504 Views, 11 Replies
can anyone help me with this situation. I've got AutoCAD LT 2010 and I can't run it due to either a DLL missing or a Display driver file not found. Anyway I get an error message window pop up then when I click ok there is a second window that appears and then it shuts down. I've tried both a repair and a reinstall but the issue keeps happening. Has anyone had this issue before and what remedy do you use to fix it?
These are the messages I got;
1st window - DLL not found: C:\Documents and Settings\Shane.Richard\My Documents\gdi10Res.dll
2nd window - A display driver file (.hdi) is missing or has been corrupted. The problem may be caused by missing .hdi files in C:\Program Files\AutoCAD LT 2010\Drv\
Shane
11 REPLIES 11
Message 2 of 12
Charles_Shade
Google and grab REVO UNINSTALLER and use its most aggressive settings, answer yes and delete everything related to LT. Most likely you have a corrupt install and need to get back to a clean hardrive in terms of AutoCAD. Turn off all programs running in the background and anti-virus/firewall programs, especially Norton.
Run thru this exercise also:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2887771&linkID=9240617
I doubt it but you may find some remnants in the registry to take out.
Restart your PC.
Then re-install. (Keep the anti-virus off)
Regards, Charles Shade
Message 3 of 12
Thanks for your help but, in the end I found another solution. What I did was copy the gdi10Res.dll (Heidi) from my AutoCAD LT 2010 folder (my link C:\Program Files\2010 AutoCad LT\Drv) and paste ti into the folder where it was missing or corrupt (my link was C:\Documents and Settings\Username\My Documents) then I restarted my computer, relaunched AutoCAD and it worked again!
Cheers for your help anyway.
Message 4 of 12
Charles_Shade
Glad that worked. Most of the time when I read someone copying and replacing a file within CAD it does not do as intended as it is usually some Registry hang that is at fault.
Message 5 of 12
I got it. My solution is got a new installer that better (you may be dowload it in the homepage of Autodesk). Ok
Message 6 of 12
none of this worked for me... is there any other recomendation?
Message 7 of 12
No need to remove any autocad or any autodesk. Just update your display driver through go to your control panel and update your system display driver only. Very easy to do it.
Message 8 of 12
Hi
R_click on ACAD shortcut --> properties ---> in Target Field make this change:
Before Change you see this: “C:\Program Files\Autodesk\AutoCAD 2014\acad.exe” /product ACAD /language “en-US
After change you will have : “C:\Program Files\Autodesk\AutoCAD 2014\acad.exe” /NOHARDWARE /product ACAD /language “en-US
(Just     NOHARDWARE /      has been added)
Do not forget to palce a space between the NOHARDWARE and the slash after it.
Apply Changes
click Ok
enjoy ACAD !
Message 9 of 12
Thanks MESHBobi, now enjoying ACAD again
Message 10 of 12
Thanks alot
very useful.
Message 11 of 12
Thank you
Message 12 of 12
U R THE BEST!
”Boost
