AutoCAD LT Forum
Dims in pspace (I am having an idiot day)
4 REPLIES 4
qfanatiq
365 Views, 4 Replies
I have a drawing, I HAVE DONE, where I have many viewports at three different scales. I have dimensioned my plans and details and they are all correct using one style.
However, I cant seem to replicate it and invisetgating the properties of the VP's and Dim's gives me nothing.
I normally hit Dim, and dim away and it automtically adjusts and scales in realtions to VP scale.
What have I done and why cant I even replicate this in this drawing?
My brain is mush and teethign baby does not help my autocad use abilities, does this even make sense?
Q
4 REPLIES 4
pendean
in reply to: qfanatiq
Is the dimstyle annotative?
Is the text style it is set to you Annotative? Is the text size correct?
Does your dimstyle have an override you might need to get rid of?
A sample DWG might help others help you further.
drjohn
DIMASSOC set to 2?
Bob_Zurunkle
in reply to: drjohn
OP are your dimensons in paperspace? Or are you trying to dimension through the viewport?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
qfanatiq
After messing aroudn with DIMASSOC I got it going.
But it did nto work on first attempt setting to -1
Q
”Boost
