AutoCAD LT General Discussion
Active Contributor
BillW435
Message 1 of 14 (6,794 Views)
Dimensions not visible in layout view
6794 Views, 13 Replies
07-26-2011 07:58 PM
This is one of those on-again off-again frustrating issues.
The problem: I add a dimension in Model Space, but it is not visible in Layout. No problem with drawing items, only dimensions. After some "floundering" (not an official AutoDesk term),  I see the dimension in Layout. Don't know what I'm doing wrong, or how I manage to get the dimensions to show again. Any and all help appreciated.
Yes, have searched the help file and manuals to no avail.
Bill
LT 2011
Windows XP
Active Contributor
BillW435
Message 2 of 14 (6,782 Views)
Re: Dimensions not visible in layout view
07-26-2011 11:23 PM in reply to: BillW435
New information:
It seems to be a problem with a new layer I made, "Dimensions", anything I add in Model space on this new layer does not appear on the Layout tab. All settings on new layer are same as layer 0, where there is no problem viewing objects on Layout tab.
Gotta be doing something wrong!
Bill
Valued Contributor
katani
Message 3 of 14 (6,773 Views)
07-27-2011 04:53 AM in reply to: BillW435
If the settings for the new layer are the same as for layer 0 which is visible in your layout viewports (all on, all thawed) then this doesn't seem to be a problem with the layer. Is the current dimension style annotative by any chance when you are adding these dimensions? Try typing ANNOALLVISIBLE at the command prompt, hit enter and change the setting to 1. Can you see the dimensions now?
PS. By suggesting reading manuals and the help file I didn't mean you will never come accross problems you will not be able to get over by yourself once you've gone through the books. I only suggested a good way to start off. Nothing mean. Honestly.
Charles_Shade
Message 4 of 14 (6,772 Views)
Make the Layout active by double clikcing inside of it.
Type LA at the Command line.
Is the Layer Thawed in the Viewport?
Layer Freeze
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Bob_Zurunkle
Message 5 of 14 (6,748 Views)
07-27-2011 09:24 AM in reply to: Charles_Shade
OP are you trying to do something with annotative dimensions? If so, then is your modelspace CANNOSCALE set to match your paperspace viewport?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Active Contributor
BillW435
Message 6 of 14 (6,728 Views)
07-28-2011 12:25 AM in reply to: BillW435
Thanks everybody -
Tried all you suggest; cannoscale is OK, annotative is OK, and layer properties appear same.
I may be asking alot, but if you care to view the file, it is attached. In model space I have entered two dimensions, one on layer "0", the other on layer "Dims". Text and dimension appear in layout view for layer "0" but not layer "Dims".
Appreciate all your help.
Bill
Olympia WA
Active Contributor
BillW435
Message 7 of 14 (6,726 Views)
07-28-2011 12:39 AM in reply to: BillW435
OOPS!
Charles, I had not tried your suggestion yet:
 "Make the Layout active by double clicking inside of it. Type LA at the Command line. Is the Layer Thawed in the Viewport?"
No, it was not thawed in the viewport - when I thawed the layer, the dimensions became visible in Layout!
Honestly, I had no idea a layer could be thawed in model space and NOT thawed in the viewport.
Again, I sincerely appreciate everyone's help.
Bill
Charles_Shade
Message 8 of 14 (6,719 Views)
07-28-2011 05:38 AM in reply to: BillW435
Glad that worked for you.
If you started with a Template open the Template and check that same Layout and Thaw the Layer.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
New Member
jmarkut
Message 9 of 14 (6,451 Views)
04-17-2012 10:29 AM in reply to: BillW435
I am unsure as to whether or not you have fixed this issue but I had the same problem and I fixed mine by the "Annotative Visability" button located on the bottom right of your screen.
Active Contributor
BillW435
Message 10 of 14 (6,440 Views)
04-17-2012 08:25 PM in reply to: jmarkut
Thanks Mark...
Well, yes I think I resolved the issue, but always can use another perspective.
Bill
