If I move, copy or stretch a dimension the text or figure associated to the dimension shows up bold. I can't find a way to re-set the text to normal. This also happens in normal text but I can remedy this by re-setting the "0" Z Geometry Position. I cannot use this method with dimensions so at the moment I re-write the dimensions and delete the old ones. This is very laborious. Is there a way of re-setting the bold text back to normal text?
Have you tried using the following
^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
That just moves everything away from z=0 to z=mahoosive and then back to z=0
Also I would check that your z axis is set to 0 to start with.
Howard Walker
Thank you for your reply.
I entered the formula into the command line but it came up as "unknown command".
I am now trying to set Z Axis to 0 in the UCS settings. Is this the correct method?
It needs to be placed in a macro button.
And you should use the below code. The previous code had a dodgy character in it.
Howard Walker
Many thanks for your help but I am still not succeeding in my mission. Whatever I type in the command line is "unknown" and I am unable to set the UCS Z Axis to 0.
Any further help would be greatly appreciated.
I'm attaching a text file. Change the extension from .txt to .scr and save it to your machine (maybe to your desktop).
Now in Autocad. Click on TOOLS. Now click on RUN SCRIPT... and choose the file (maybe on your desktop) it should now be callled flatten.scr
Howard Walker
Good afternoon.
Eventually, and with a little help from a colleague, I used your formula, created a Macro button and now my problem has been solved.
Many thanks for your help. This has made things so much easier.
