1. Open the Dimension Style Manager
2. Select your dimension style and pick the Modify button
3. Select the Lines and Arrow tab
4. Under Arrowheads, in the lower right, are you using a predefined arrow or
a User Arrow (at the bottom of the pull-down lists)? Use can also check the
values of DIMBLK1 & DIMBLK2.
If you are using a User Arrow, then you may have two different block
definitions of it in the two drawings. It may be larger in one drawing and
smaller in the other. First check out this possibility.
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
"QfanatiQ" wrote in message
news:16557581.1073829764698.JavaMail.jive@jiveforum1.autodesk.com...
> "Do the dimension styles use a user defined block for the arrow heads, and
are they the same in both drawings?"
> I'm sorry not sure what you mean there.
> I created Dimension styles a while back, these i then locked onto a .dwt
file for other users at work.
> I only discovered the dimension difference when i brought in a block (for
temp use), upon insertion the arrows where huge, yet the number beside
Arrows under the Lines and Arrows heading in the Properties reads the same
as in other drawings where the dimension style draws correctly.
> I was hoping/thinking this would be a scale issue, or a system variable.
> Just checked and the properties for them are both the same?
> This was a drawing simply saved as and reworked, I did insert the original
Survey, I have just now deleted, purged & Audited the drawing (no errors).
> Yet the dimension size is still the same (too big).
> Ok just took everything out of the drawing, stripped it right down, drew a
Dim and HUGE...
> Might just set up the pages again as the new .dwg I have just created and
inserted the drawing into dimensions correctly.
> Still curios to knwo how to rectify this problem though.
> Cheers.....Q
