AutoCAD LT Forum
Dimension Font Sizes
3 REPLIES 3
23409 Views, 3 Replies
I'm having trouble changing the font sizes in dimensions. If I right-click
on the dimension and use the editor, I can change the font but if I change
the size setting (like, from 1' to 6") the font size remains the same.
Any ideas on how to do it? Is it font-dependent? If so, what type of font
do I need to use?
Also, how do I change the font and size for the dimensions for the whole
drawing?
Thanks for your help.
3 REPLIES 3
If you explode the dimension, you can use the "Properties" tool button and
change the font size.
For new dimensions of a different font size, the format menu lets you choose
dimension style/annotation settings which will set the properties for all new
dimensions added to the drawing.
As far as changing the whole existing drawing dimension text size - I don't
know.
Hope this helps.
Don
> do I need to use?
> drawing?
You might also try:
"format"
"dimension styles"
then change the text height to what you want,
remember to save the changes and all dimension text of that style will
change accordingly.
John Martin and Don:
Thank you for your quick response. It'll be a day or so before I get to try
your suggestions, but I appreciate your help. I'll let you know how it
goes.
Matt
HP Authorized Customer wrote in message
news:ef043ac.-1@WebX.SaUCah8kaAW...
right-click
font
> do I need to use?
> drawing?
”Boost
